25 hp Mercury EFI 4 Cycle Fuel issue
Oger1
My 2006 25 hp Mercury 4 Stroke EFI not getting Fuel out of VST . I can jump the High Pressure Fuel Pump in the VST and Fuel flows fine . I'm getting current to the two Wire Connector on top of the VST when pull starting engine .Please help
I have this same problem and cannot figure it out. Only difference is that mine is a remote start. Hope you figure it out.
There's a float switch inside that may be causing your issue you can remove it and turn upside down and right-side up to test it to see if it's opening and closing properly.
