I have a 2004 9.9 with power trim/tilt and electric start (BABJ 1302797) experiencing a starting issue with the electric start.
Intermittently when I push the electric start button it clicks and will not turn over. When this occurs it disables power to the trim/tilt also. The motor will still pull start fine.
The batteries are new/charged and cable connections are clean. Two battery system that runs the main motor, downriggers, electronics etc. and all work normal.
After a few minutes (5-10) the problem seems to reset itself so that the electric tilt works normal. If I only use the electric tilt and pull start this never happens.
It seems to me like there is an auto resetting breaker that gets tripped since there is a click and then after a few minutes sitting the tilt works fine. I've gone through the parts diagram and can't seem to identify a resetting breaker to look at.
This happens about half the time I use the electric start. It works normal and starts the motor the other times. Knocking out the tilt is a big problem since the motor is stuck down when I need to move on the main.
Any ideas are greatly appreciated.
