Results 1 to 6 of 6
    Default Help identifying which lower is on my Evinrude
    I am trying to identify what lower is on my 1989 E140TLCEB. From what I can tell there are 3 possibilities.Ttwo standard rotation and 1 counter-rotation. I've ruled out the counter-rotation based on my prop. So, I am unsure how to determine which of the other two that I have. Thanks for your help!!
    Sep 2010
    18,405
    Default Re: Help identifying which lower is on my Evinrude
    Some had a V-6 lower unit on them.----Any numbers on the prop ?-----Fine thread on the prop nut ?
    I will need to pull the prop to get the number off of it tomorrow. It does have fine threads threads on the prop shaft.
    Sep 2010
    18,405
    Fine threads make it a V-6 lower unit.------The V-6 unit was used for a few years.---The V-6 lower unit was used on the " commercial " motors as well.
    So, how would I find out the part number for the lower? I need to redo all the lower seals & want to make sure I get the correct kit.
  6. #6
    Sep 2010
    18,405
    Easy for me.-----But the factory seals do have a part # on them.----Magnifying glass may be needed-----Then order the kit with those seals.-----Easier to find the kit then the way you think at the moment.
  1. need help identifying lower unit
    By BOATMAN13X1 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-26-2015, 10:37 AM
  2. Identifying a lower unit
    By regrubuen in forum Mercury Mariner Outboard Forum
    Last Post: 07-16-2014, 06:56 AM
  3. Identifying a lower unit
    By regrubuen in forum Identifying Model / Year / Horsepower
    Last Post: 07-15-2014, 11:23 AM
  4. Help identifying lower units pics
    By monte in forum Chrysler Force Outboard Archive
    Last Post: 01-26-2008, 04:25 PM
  5. Help In Identifying OMC Stern Drive Lower Unit
    By David Jordan in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-29-2004, 02:10 PM
