MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
  1. #1
    Default 1980s 50hp mercury pump question
    Need some help answering kind simple a question
    Will the water pump operate when the engine is only used with throttle only (ie gear is disengaged)
    or does it have to be in neutral or in gear to operate
  2. #2
    Join Date
    Sep 2010
    Posts
    18,482
    Default Re: 1980s 50hp mercury pump question
    When the motor turns / runs the water pump should be working !!-----The shifting is done along the propeller shaft.----The pump is driven by the driveshaft.----Why the question ?
  3. #3
    Being having problems with the pump on muffs, changed it, ran compressed air throw the telltale, it seemed to be clear. When I run it on muff nothing and when its in the lake it pumps great.
  4. #4
    Join Date
    Sep 2010
    Posts
    18,482
    Some motors are shy and do not pee well with neighbors watching.
  5. #5
    lol
    Just worried about overheating it as I want to give it decent run before the lake
  6. #6
    Join Date
    Sep 2010
    Posts
    18,482
    There is not really much that you can do wrong with one of these pump repairs.----That is my opinion.-----If you are worried you need to install a water pressure gauge.----Any boat shop will be glad to help you pick one out suited for your motor !
  7. #7
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    16,537
    If you're running it in a small barrel or on muffs, it can be starved for water and run hotter. If you run the boat on the trailer at the ramp you can be assured it's okay or not.
    This is also a great way to determine if the motor is "taking gas" correctly and making ful power. Just don't hold her wide open for more than a few seconds.
    Jeff
Similar Threads
  1. 50hp water pump question
    By T00lmanii in forum Johnson Evinrude Outboard Forum
    Last Post: 02-15-2018, 11:01 PM
  2. Mercury 50hp blue band thunderbolt, 1980s
    By TJS in forum Mercury Mariner Outboard Forum
    Last Post: 09-27-2016, 05:35 AM
  3. 1980s Mercury Classic 50 Back-to-life
    By anjp in forum Mercury Mariner Outboard Forum
    Last Post: 03-31-2014, 09:14 PM
  4. Problems with overheating on my 7.5hp 1980s mercury outboard. please help
    By Dutch Oven in forum Mercury Mariner Outboard Forum
    Last Post: 05-29-2012, 07:03 AM
  5. 1980s mercury tower of power problem
    By brokensword in forum Mercury Mariner Outboard Forum
    Last Post: 08-01-2011, 06:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
