Results 1 to 6 of 6
    Default Tilt and Trim Sending ?
    2002 Honda 130 HP
    Bought it already on boat. I want to add a tilt and trim gauge on the dash. How does the motor send the signal to the gauge ?
    Where does it connect to on the motor?
    Default Re: Tilt and Trim Sending ?
    on my 1997 BF90 the trim/tilt angle sending unit is located on the left stern bracket next to the trim and tilt unit
    Thanks Robert. I'm not near the boat right now, but will check out your suggestion. Thanks Again !!!!
    90% sure the sender is already there and all the wiring is in place. look for three unused wires under the gauges. light green, light blue and white/black.
    You may be correct. I will investigate further. Thanks Bruce
  6. #6
Name:	Instrment wiring.jpg
  1. Trim / tilt sending unit
    By CarltonS in forum Johnson Evinrude Outboard Forum
    Last Post: 09-26-2019, 11:57 AM
  2. Trim / tilt sending unit
    Last Post: 09-26-2019, 09:58 AM
  3. 1979 evinrude 85HP Tilt/Trim Gauge/Sending unit
    By Brutus101 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-29-2017, 08:37 PM
  4. tilt trim sending unit ???
    By shockman in forum Johnson Evinrude Outboard Forum
    Last Post: 08-27-2014, 12:48 PM
  5. Tilt n trim sending unit
    By dannyvan in forum Johnson Evinrude Outboard Archive
    Last Post: 04-15-2009, 08:45 AM
