Click for Volvo Penta parts and manuals!
Results 1 to 3 of 3
  1. #1
    Default 290 serial number
    I have a 290sp that needs work. Can anyone tell me what drive I have (gear ratio etc) if I have the serial number? 2900701B
    Robert
  2. #2
    Default Re: 290 serial number
    Its behind a V8 (350) if that helps.
    Robert
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    11,676
    Remove the propeller, remove the ring anode and wire brush the AFT end on the prop shaft bearing carrier.
    The numbers 1.61 should be stamped into the carrier.
    For the s/p drive, 1.61:1 is the correct over-all reduction for the V-8 engine.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
    "Intellectual growth should commence at birth and cease only at death." Albert Einstein
    Please... no PMs! Post your questions on the forum.
Similar Threads
  1. 1994 Johnson 112 model number help I have serial number
    By dreese2005 in forum Identifying Model / Year / Horsepower
    Last Post: 12-01-2016, 03:37 PM
  2. Serial number cannot be found but we have the casting number
    By Luc Perreau in forum Identifying Model / Year / Horsepower
    Last Post: 11-07-2013, 09:09 AM
  3. Replies: 0
    Last Post: 04-08-2011, 08:28 PM
  4. Replies: 7
    Last Post: 03-30-2011, 09:01 PM
  5. Model number and serial number id plates location
    By mike in forum Archive 2003-2009
    Last Post: 10-19-2003, 03:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
