Results 1 to 8 of 8
  1. #1
    Default 1961 evinrude fastwin 18 to electric start
    old lurker looking for help. I have a 1961 two stroke 18 fastwin 18 I need to put electric starter on. I've been told it can be done. This is a tiller motor mod 15034. Can anyone point me in the right direction on part numbers for bracket, motor and all other parts I need. I am a rookie when it comes to outboards. I greatly appreciate any help. Thank you all.
  2. #2
    Join Date
    Sep 2010
    Posts
    18,407
    Default Re: 1961 evinrude fastwin 18 to electric start
    Your best bet is to find a donor motor.-----Johnson or Evinrude 22 cubic inch ----1958 to 1976 ------sold as an 18 , 20 , 25 hp model.------Or E-bay if you don't have time and lots of cash.-----Check e-bay listings carefully.
  3. #3
    Quote Originally Posted by racerone View Post
    So parts from a johnson will interchange with no problems then. Thank you.
    Part numbers would help if anyone might know what they are.
    Thank you racerone for the info.
  4. #4
    Join Date
    Sep 2010
    Posts
    18,407
    There is a box on this page.------ENGINE DIAGRAMS---Just a few clicks.------Look up the motors.-------Make your list of parts you need to look for that are within your budget.-----The ring gear for flywheel was listed very early.-----Electric start kits were a factory accessory , dealer installed as early as 1958 models.----1974 models were first listed as electric start on this site.----As I said DONOR motor is the way to go for all the parts
  5. #5
    Thank you racerone. I found the diagram page. I still haven't found a donor motor yet, but will keep looking. Arthoritise is making it difficult to pull start this thing...
  6. #6
    Join Date
    Sep 2010
    Posts
    18,407
    Perhaps check that the recoil starter is properly set up.------Yes these motors need a bit of oomph to pull over.------I used to lift these motors with ease but now I struggle with a 10 HP model like that.-----Lots of these motors around for parts in some areas.----Your location ?
  7. #7
    Racerone, I am currently in Springfield, Mo. Probably moving with-in a year maybe a bit more to the Phoenix, Az area...
  8. #8
    Join Date
    Jun 2013
    Location
    Duluth Mn
    Posts
    2,408
    Try Tim's Outboard in Hackensack MN. Mike or Dan may be able to set you up with a kit. 218 682 2331. Any lakes where your going? They allow 2 strokes?
Similar Threads
  1. 1961 Evinrude Fastwin 18 HP not shifting
    By kensho1976 in forum Johnson Evinrude Outboard Forum
    Last Post: 07-07-2012, 06:37 PM
  2. 1961 evinrude 18 hp fastwin
    By smitty1244 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-24-2009, 02:58 PM
  3. 1961 evinrude 18 hp fastwin parts
    Last Post: 07-23-2009, 07:12 AM
  4. 1961 evinrude 18 hp fastwin
    Last Post: 05-18-2009, 05:35 PM
  5. 18HP Evinrude 1963 Fastwin convert to electric start
    By gallipoli in forum Johnson Evinrude Outboard Archive
    Last Post: 07-28-2006, 03:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
