water in carb of 90 hp force but not from the gas
How much water is ---" lots of water " ---in this case.-------You are aware that a carburetor runs cold and this may be due to condensation.
hi lots of water non in seperator or gas run at idle in barrel win run great then bog and then there is water in all bowls of the carbs not from the gas
hi we did that drained carbs new tank hose and added a seperator and it still got ater in it . when we put it in the lake hi idle or full throtle runs good no misses but when you slow down it stalls then hard to start stalls when shifting ,
The way the motors made, the only way the water could get in the carbs is through the fuel pump.
The pump operates off the #2 cyl.
If the block had a crack in the cooling passage around #2 it could get in through the diaphragm???
Pull the pump, check the diaphragm?
Pull the port cover and check for rust, water?
Stalling at low speed, water in the gas.
