Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 7 of 7
    Default water in carb of 90 hp force but not from the gas
    Iam getting lots of water in the carbs of my 1989 85hp force out board . it is not from the gas
    Sep 2010
    18,405
    Default Re: water in carb of 90 hp force but not from the gas
    How much water is ---" lots of water " ---in this case.-------You are aware that a carburetor runs cold and this may be due to condensation.
    Quote Originally Posted by racerone View Post
    hi lots of water non in seperator or gas run at idle in barrel win run great then bog and then there is water in all bowls of the carbs not from the gas
    Sep 2010
    18,405
    Test run with another tank and hose.
    hi we did that drained carbs new tank hose and added a seperator and it still got ater in it . when we put it in the lake hi idle or full throtle runs good no misses but when you slow down it stalls then hard to start stalls when shifting ,
  6. #6
    May 2010
    Sebastian ,Fl
    2,912
    The way the motors made, the only way the water could get in the carbs is through the fuel pump.
    The pump operates off the #2 cyl.
    If the block had a crack in the cooling passage around #2 it could get in through the diaphragm???
    Pull the pump, check the diaphragm?
    Pull the port cover and check for rust, water?
    Stalling at low speed, water in the gas.
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
    88 Bayliner with 2002 225 HP Mercury
    Buy American made Cars and Trucks!!!Towing insurance,get it.
    In Scenic Beautiful Sebastian by the sea Florida
  7. #7
    Thanks i will try that i never thought of checking the pump
  1. Looking for carb set for 125hp 1985 force plus carb question
    By Longislandboater in forum Chrysler Force Outboard Forum
    Last Post: 07-20-2014, 07:43 AM
  2. 9.9 force carb issues
    By zero_tolerance in forum Chrysler Force Outboard Forum
    Last Post: 06-17-2010, 12:21 AM
  3. 95 mercury force 50 hp carb
    By bigfish3939 in forum Chrysler Force Outboard Forum
    Last Post: 12-19-2008, 01:48 AM
  4. 90 HP Force Carb Problem
    By troy_hubers in forum Chrysler Force Outboard Archive
    Last Post: 06-01-2008, 09:26 PM
  5. 87 force 50 carb problem
    By cosmict in forum Chrysler Force Outboard Archive
    Last Post: 05-09-2008, 09:09 AM
