Results 1 to 5 of 5
  1. #1
    Default No feul to bottom carb on 08 Yamaha 2 stroke
    Went to lake Ann boat wouldn't open up. Would only go about 8 mph. Came home changed gas, feul/water seperater filter, and spark plugs. Went back to lake boat got up to about 20/25 mph. Took cover off of the carbs and realized there is feul squirting in top two carbs but not the bottom. Any ideas.
  2. #2
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,912
    Default Re: No feul to bottom carb on 08 Yamaha 2 stroke
    Clean the carb. Float is probably stuck.
    Don't use carb soaks, it can damage any plastic that might be there.
    I use the cheap carb/brake cleaner from WallyWorld.
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
    88 Bayliner with 2002 225 HP Mercury
    Buy American made Cars and Trucks!!!Towing insurance,get it.
    In Scenic Beautiful Sebastian by the sea Florida
  3. #3
    Quote Originally Posted by Jerryjerry05 View Post
    Ok thanks Jerry I did use some Sea foam in the carb but not a whole lot. I always put Sea foam in the gas tank when it's empty and I fill up to help preserve the gas, I was told to do this by our local marina. I always mix it half the ratio that the can says to. Is this ok or do I need to use a different type of fuel stabilizer. Also when I park my boat in the shop should I leave the motor trimmed up like I'm towing or should I leave it trimmed down.
  4. #4
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    5,820
    I think he is telling you to remove the carb, take it apart and clean it.
    You cannot just add a magic chemical to your fuel to accomplish this.
    If you do not want to pull your carb and continue to put chemicals through your engine don't worry the problem with your carb will become minor.
    This is a simple job.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  5. #5
    Quote Originally Posted by Docksidemarineservices View Post
    Thanks for everyone's help I have Removed the carb took bowl off and it was very clean I squirted some cleaner thru the hole the gas line connected to and put back together and everything is running smoothly must have had a peice of dirt in it or something again thanks for everyone's help
Similar Threads
  1. Mid 90's Yamaha 40 2 Stroke carb help
    By cubegleamer in forum Yamaha Outboard Forum
    Last Post: 01-14-2020, 01:39 PM
  2. yamaha 9.9 4 stroke carb rebuild
    By captainkeene in forum Yamaha Outboard Forum
    Last Post: 07-19-2019, 10:52 PM
  3. 1997 Yamaha 25hp bottom carb not getting fuel
    By irizarry44 in forum Yamaha Outboard Forum
    Last Post: 05-14-2015, 02:58 AM
  4. linkage on bottom carb on 2 stroke 90
    By mcatan2468 in forum Yamaha Outboard Forum
    Last Post: 12-02-2009, 11:45 AM
  5. Carb problems on a 99 Yamaha 4 stroke
    By fcj in forum Yamaha Outboard Archive
    Last Post: 03-02-2009, 04:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
