Results 1 to 4 of 4
  1. #1
    Default VRO Pump Question
    I just purchased a boat with a 1999 40 HP Johnson outboard, model #J40PLEEA. I know there are varying opinions on this, but I am contemplating removing the VRO pump, at the same time as rebuilding the carbs. Images of the replacement pump seems to have three nipples; in, out, and pulse? I thought that the pulse came from the back side of the pump where it is mounted. I guess my question is, are there two pulse connections? Thanks in advance, Dave
  2. #2
    Join Date
    Sep 2010
    Posts
    18,391
    Default Re: VRO Pump Question
    Fact.----A replacement pump used on 48 HP models mounts directly over a pulse port on the port side of the # 1 cylinder.-----It uses 2 nipples one for fuel in and one fuel out.----Cheapest way to go.----You would block off the VRO pulse port.
  3. #3
    Thank you for the reply. I'm just wondering, can I use the screw that I remove for the pulse behind the new fuel pump, and use it to plug the VRO pulse port?
  4. #4
    Join Date
    Sep 2010
    Posts
    18,391
    If it has the same thread as the pulse limiter you can use it.
Similar Threads
  1. Replies: 4
    Last Post: 05-31-2016, 12:39 PM
  2. A New VRO Pump Question
    By WaitUpGuys in forum Johnson Evinrude Outboard Forum
    Last Post: 04-12-2016, 10:12 AM
  3. Question about my pump
    By jpugh001 in forum Mercury Mariner Outboard Archive
    Last Post: 07-02-2008, 04:53 PM
  4. Oil pump question
    By sdadean in forum Mercury Mariner Outboard Archive
    Last Post: 05-12-2008, 04:32 PM
  5. b82 Gamefisher 75 hp Element Pump fuel pump question
    By sunguy in forum Archive 2003-2009
    Last Post: 11-13-2006, 11:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
