I have had this boat and motor about three years, first year, dirty gas issues as it had sat a few years. 2nd year I got rough running again and replaced 2 pencil coils, 4 plugs and had fuel injectors cleaned and calibrated.
Started getting rough running again this last month, I replaced 4 plugs, 4 pencil coils, fuel line, added a water separator filter, and added a Vessel View Monitor.
Two different shops did the work on year one and two, the last months repairs and adding vessel view, I did.
Today I ran the boat and it went well initially running right up to 6400 rpm's ran there with 127 degree temp, 11 GPH . After a 20 minute run at 1600 rpm's i hit throttle and it lugged upto 3000 rpm and stuck between 3000 and 4000 rpm's, fuel GPH stayed low at less than 7GPH.
What I got from vessel view is a fault code: Camshaft Synchronization - Crankshaft or camshaft encoder is not working properly. (Picture with more detail is attached). Does this make sense to the symptoms? Any advice is appreciated, I would like to repair myself or is this a good idea for shop repair??
Thank you for advice and thoughts!! John
