Well, it looks like it won't allow me to properly upload a PDF file today.
So if I can't show you the picture, it's a two-prong connector that is normally tucked in behind the VST. There is enough slack in the harness to pull it out and unplug it for testing. Before you unplug it, have someone turn on the key switch while you are near the engine so you can heard whether the pump comes on for 2 seconds. If not, then unplug it, hook up a voltmeter - positive to blue/yellow and negative to black. Have someone turn on the key switch again while you watch the voltmeter. You should read battery voltage for 2 seconds. If not, then check your fuses.
