Click for Volvo Penta parts and manuals!
Results 1 to 12 of 12
  1. #1
    Default Do carbureted engines have a steady idle?
    There may have been something wrong with my engine, but my old carbed gm350 volvo I/O always had a little bit of a surge +/- 50rpm and it drove me nuts, then of course when you put it in gear it would drop about 200rpm, so It always idled a little high in neutral to prevent stalling. After we rebuilt the carb I think it only dropped 100rpm, but anyways, I replaced the engine with a MPI engine and the rpm is as steady as can be. When I shift gears I think it drops just a tad for a couple seconds, then it's back to sitting at a steady 700rpm, just like a car and boy am I a happy camper. So was there something wrong with my old engine or is that just nature of the beast? I love the fact that I can maneuver at the dock and not worry about the engine stalling.
  2. #2
    Default Re: Do carbureted engines have a steady idle?
    I know the MPI engine is can change the amount of required fuel instantly for the load, so I guess that's the difference?
  3. #3
    I have had carbureted engines idle very smoothly. Likely carb or ignition items were an issue but if you get the need to replace the engine any high wear engine where compression is significantly different cylinder to cylinder or valance wear is different could also contribute to idle varying.
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,025
    When they are 'right' they are 'steady'...
    On the MPI engines, the ECU recognizes the RPM drop when shifting into gear and opens the IAC valve a bit, to compensate....
  5. #5
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,896
    Ayuh,..... My carbed motors have always idle smoothly,...... do alotta that freshwater trollin',......
  6. #6
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    11,580
    You mentioned "my old carbed gm 350 Volvo I/O".
    May we assume that this engine is equipped with a mechanically advancing ignition system?
    If not a carburetor issue, please read on.
    (disclaimer.... this is a long shot!)
    .... at idle speed, there is no mechanical advance being added to BASE advance.
    .... BASE advance should be constant at either 8 or 10 degrees BTDC.
    .... your system uses a flyweight/cam affair (2 of these).
    .... the flyweights are controlled by two small springs that pull them both back into (and keep them in) BASE mode at idle speed.
    .... the spring value allows the flyweights to
    progressively advance the spark event as RPM increase above idle speed.
    .... when/if the flyweight return springs have become rust compromised, they loose their spring value.
    .... when/if they have lost their spring value, they will not consistently pull and hold the flyweights back into BASE ADVANCE mode.
    .... if this was to occur, the spark "lead" at idle may be somewhat erratic or pulsating, so to speak.
    .... even with a good fuel delivery system, a pulsating BASE advance spark event (of let's say 2 degrees or so) will present itself as engine RPM "surging".
    Connect up your standard mode timing light.
    With the engine at idle speed, see if the BASE advance is steady or if it is erratic.
    If the BASE advance is erratic, your flyweight system is not holding BASE advance at idle speed, of which may indicate weak springs.
    CAUTION:
    Do not haphazardly replace the flyweight return springs (no matter what the supplier says) without the aid of a shop who owns/operates a Sun, Allen or King distributor machine.
    These little springs not only hold BASE advance while at idle speed, their spring value also controls the very important progressive advance.
    Again, this would only apply if all else is OK.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
    "Intellectual growth should commence at birth and cease only at death." Albert Einstein
    Please... no PMs! Post your questions on the forum.
  7. #7
    The old one had a prestolite ignition which I believe was electronic.
  8. #8
    This is an 89 GM350 volvo aq271c 275hp
  9. #9
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    11,580
    Quote Originally Posted by Fishmaster23 View Post
    1989 pre-dates Volvo Penta's use of the EST system. (EST = electronic spark timing, of which does not use a mechanically advancing system)
    Even with a Prestolite electronic triggering system, it will still incorporate a mechanical advance.
    Try what I suggest in post #6.
    Portland, Oregon
  10. #10
    In first post, OP stated he replaced this engine with an MPI engine, so doubt he can check the advance mechanism anymore
  11. #11
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    11,580
    Quote Originally Posted by Dieter
    Yes, the MPI engine would use an EST ignition system that would not incorporate any mechanical advancing.
    Original thread title: "Do carbureted engines have a steady idle?"
    In post #1 Fishmaster asks about his old carbureted engine regarding a bit of an RPM surge.
    There may have been something wrong with my engine, but my old carbed gm350 volvo I/O always had a little bit of a surge +/- 50rpm and it drove me nuts, then of course when you put it in gear it would drop about 200rpm, so It always idled a little high in neutral to prevent stalling. After we rebuilt the carb I think it only dropped 100rpm, .................................
    Portland, Oregon
  12. #12
    I think the old engine had a bad power valve too. Found out the adjustment screws on the carb were only .50 and .75 turns out yet it still ran.
Similar Threads
  1. Engines stall at idle speed
    By LowPressure in forum Yamaha Outboard Forum
    Last Post: 05-09-2019, 11:42 AM
  2. Replies: 2
    Last Post: 06-14-2012, 06:00 AM
  3. 502 XLi Crusader Engines Port will not idle
    By rogerledbetter in forum Crusader Marine Engine Forum
    Last Post: 09-21-2009, 12:29 PM
  4. Engines die out at idle
    By narcosis in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 06-16-2008, 08:47 AM
  5. Getting Started with idle Evinrude engines
    By Tom Adams in forum Outboard motors archive 2000-2004
    Last Post: 06-02-2002, 11:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
