Results 1 to 12 of 12
  1. #1
    Default Rebuild question
    So Ive decided to rebuild my engine, for no other reason then piece of mind. Got a 87 cobalt with a 454 and alpha1. Shes a mature lady but she runs well. I pulled the engine and tore it all down, no signs of hot spots, cracks or anything like that. So things look good.
    The plan is to have everything hot tanked, inspected and cleaned up. New rings, main, rod and cam bearings, valve job etc. Just want to freshen her up.
    Ideally Id like to find a shop to build me up a long block and Ill just take care of the top end at home.
    anyone have any ballpark figure on what that might run me?
    Located in California
    thanks in adavace
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,017
    Default Re: Rebuild question
    Shop rates vary a lot...and I'd expect CA to be on the high end....best to call around, or visit and ask.....sometimes its better to let them supply the necessary parts....and essential for the cam bearings unless you have the toolset.....
    ballpark - between 500 & 700 depending upon what needs to be replaced in the heads....
  3. #3
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    5,369
    If you put it all back together yourself it may be less but my estimate would be- $1500-$2000. If less then you have beer money!
    A SHORT block assembled (no heads)/typically no oil pump or pan/no water pump and in some cases no timing chain cover.
    LONG block assembly includes heads/push rods/rockers/oil pump/pan. All assembled. Best way to go. The rest is on you to assemble.
    Heads alone will most likely run around $500 if done right.
    Block should be decked, squared, honed, Crank reworked/massaged and properly balanced!! If they are good they will make all piston rods and piston assemblies as close to the same weight as possible........makes for a very smooth idle and very little vibration throughout the rpm range.
    They will know if there is a need to be oversized bore or not and if so then new pistons/rings.
    New rings even if no new oversized pistons. Complete engine Bolt kit. New Oil pump. Double roller timing chain with new sprockets, Engine gasket (Marine) kit. You may also need new push rods but they will make that call.
    I am sure there are additional things to consider......
    Jack
    Mass.
  4. #4
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,894
    Ideally I’d like to find a shop to build me up a long block and I’ll just take care of the top end at home.
    Ayuh,...... I think yer gonna have a tough time findin' anybody to put it back together, without some machine work, 'n matchin' new parts,.....
    A shop has to stand behind their work,....
    That's tough to do on a 1/2azzed reman,.....
  5. #5
    What do you mean the top end? You mean you want the shop to build you a short block, then you'll put the heads on yourself making it a complete long block? Are you going to let them redo the heads too?
  6. #6
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    16,437
    Nothing like a pre-run (on a dyno) semi-broken in long block with a guarantee! May even be cheaper in the long run.
    Jeff
  7. #7
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    11,562
    Thread title says "Rebuild Question"
    If you are wanting to simply clean things up and re-assemble (as a "freshen her up" w/ new rings/bearings/valve job, etc), this would be a re-furbish, not necessarily a rebuild.
    Quote Originally Posted by 805HD View Post
    So I’ve decided to rebuild my engine, for no other reason then piece of mind. Got a ‘87 cobalt with a 454 and alpha1. She’s a mature lady but she runs well. I pulled the engine and tore it all down, no signs of hot spots, cracks or anything like that. So things look good.
    I'm sure that you could find a shop who would hot-tank your components, clean things up and check for cracks, etc.
    However, I think that you'd be hard-pressed to find a shop
    who would be willing to offer any type of warranty under those conditions (i.e., an assembled short block while re-using pistons, non-reconditioned rods, existing cam, etc.)
    I would suggest that you
    have the shop do an actual "rebuild" for you whereby they can offer you a warranty.
    If need be, go first over and with new pistons and fully reconditioned rods, turn or polish the crankshaft within specs, new camshaft, etc.
    If you go with inexpensive pistons, you're looking at spending around $250 or less (you'd be buying piston rings anyway)
    If you go with a good Hypereutectic alloy
    piston set, you're looking at spending a tad bit more.
    A new Marine BBC flat tappet cam and cam followers will cost you about $200 or perhaps a bit less.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
    "Intellectual growth should commence at birth and cease only at death." Albert Einstein
    Please... no PMs! Post your questions on the forum.
  8. #8
    All valid points.. and yes I would have the heads done as well...
    anyone have any recommendations on a good company to get a short or long block?
  9. #9
    Join Date
    Dec 2006
    Location
    Posts
    5,894
    Ayuh,........ Try here,.....
    A used motor in a rotten boat might be a cheaper option,..... a donor boat,... scrap, or trash what's left,....
  10. #10
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    5,369
    If your engine is in good condition I would use that. No need to purchase a second one.
    If you do your research in your area try to find a shop who does performance engine building and as suggested, possibly has a dyno to pre-run and tune the engine.
    Purchasing a standard off the shelf short block has no advantage in your situation. If your engine block was bad then yes but because if is fully operational, going to a reputable shop and having it "freshened" up is the right direction to go..
    NOTE: because you have an ALPHA drive you have a limit on power. even OEM 454 power levels (torque) have that drive at its maximum capability level.
    So you MUST keep the torque of the engine at its OEM level. I am surprised the drive has lasted this long!
    Jack
    Mass.
  11. #11
    Join Date
    May 2010
    Location
    DC Burbs/Maryland Eastern Shore
    Posts
    1,700
    I will go the opposite direction here. If you like this boat and want to keep it, I would go to your friendly neighborhood Mercruiser dealer and look into a new power/drive package. Yes it will be a load of money but they will finance it and it might be more affordable than you think. Definitely go find out what they can do for you.
    Get new controls and gauges while you're at it.
    It will start and run flawlessly, give you more speed and lower fuel consumption, have warranty, be serviceable by any mercruiser shop, blah blah blah...
    If you rebuild you'll be into it for several thousand, and still be right where you were before doing all the work/spending the time. A whole new everything will allow you to get out on the water sooner with far more peace of mind than your rebuilt lump and 30-odd year old drive. As others have said machine work is expensive and rebuilding an engine is far more costly than simply buying a rebuilt long block from a remanufacturer. It's about 3500 for a off the shelf rebuilt 454 long block. Your machine work alone is going to be in the 2-2500 range and then there's parts. They will charge you retail plus premium at the machine shop.
    Practicing the ancient art of ren-ching
  12. #12
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    3,170
    Quote Originally Posted by o2batsea View Post
    Ditto.... I've reengined two boats and was planning the re engine of a third when I had to sell it ( divorce). All three times, when I did the cost /benefit analysis including my time and warranty issues ( in your proposed scenario you have none!!) I ended up buying a new factory crate engine... since I run in sea water, I ordered them with the "Fresh" water cooling kits.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
Similar Threads
  1. Carburetor Rebuild Question
    By antx227 in forum Nissan Tohatsu Outboard Forum
    Last Post: 05-01-2017, 09:51 AM
  2. 43L Rebuild Question
    By bill_buck in forum Mercruiser Sterndrive Forum
    Last Post: 12-22-2009, 11:32 PM
  3. Rebuild or no rebuild that is the question
    By axiom in forum Johnson Evinrude Outboard Archive
    Last Post: 01-12-2009, 07:46 PM
  4. Carb rebuild question
    By roz58 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-08-2007, 11:39 PM
  5. Another Carb rebuild Question
    By chris in forum Archive 2003-2009
    Last Post: 07-23-2003, 05:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
