MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 6 of 6
  1. #1
    Default 15 hp 2 stroke carburetor pump diaphragm
    I purchased a Quicksilver repair kit, 1395-823707-2.
    This has the gaskets and diaphragm for the water pump.
    The question is, where does this neoprine gasket go?
    This is the diaphragm for the pump.
    The documentation does not show this gasket.
    Kevin
  2. #2
    Join Date
    May 2015
    Posts
    2,065
    Default Re: 15 hp 2 stroke carburetor pump diaphragm
    that kit fits several different carbs and hp motors. So.you may not need that diaphragm.
  3. #3
    Join Date
    Sep 2010
    Posts
    18,113
    Serial # of your motor ?
  4. #4
    Quote Originally Posted by racerone View Post
    serial # of your motor ?
    1b909879
  5. #5
    Its for the older models that dont have the metal reed valves in them.(The diaphragm has reed valves as part of, first pic here)
    Second pic is the later type.
  6. #6
    Join Date
    May 2015
    Posts
    2,065
    [QUOTE=mykc;671397]Its for the older models that dont have the metal reed valves in them.(The diaphragm has reed valves as part of, first pic here)
    Second pic is the later type.[/QU
    Yes the later carbs have a plastic spacer with check valves built into it.
Similar Threads
  1. Replies: 4
    Last Post: 04-26-2019, 07:29 PM
  2. accelerator pump diaphragm!
    By Joseph Durgin in forum Mercury Mariner Outboard Forum
    Last Post: 09-08-2016, 02:41 AM
  3. Fuel pump kit check valve diaphragm difference
    By sliales in forum Mercury Mariner Outboard Archive
    Last Post: 07-25-2009, 01:48 PM
  4. Diaphragm pulsator for a simms pump
    By matzke in forum Ford Lehman
    Last Post: 05-06-2009, 05:12 PM
  5. Fuel Pump Diaphragm Kit Missing Parts
    By gizmoi in forum Mercury Mariner Outboard Archive
    Last Post: 08-19-2007, 10:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
