Click for Crusader parts and manuals!
Results 1 to 8 of 8
Thread: Please help
    Default Please help
    1979 fish natique.. 454 with 1410 marine carb . Pertronix dist and wires. Engine 2 years old carburetor and distributor system only 1 year old..park the boat late August and just trying to crank it this weekend and it is running rough and backfiring... I replace the spark plugs for process of elimination.. usually backfires when first giving it gas. Then again at idle I hear some popping out the exhaust..
    Mar 2009
    Dresden, Maine, United States
    362
    Default Re: Please help
    Have you changed your fuel filters and how old is the gas? I would douse the tank with sea foam and see if that helps.
    Gas is 5 month old and was parked with seafoam . Fuel filter changed over summer .... I was reading last night ( dust cap may have moisture... Gonna eleimonate dat today
    Sep 2008
    Maryland - USA
    8,017
    a wet distributor cap can cause the popping noises you described....so can a leaking valve....
    Eliminated the wet distributor today. Unless corrosion settled in at some point. I'm afraid valve may be it... Strange thing is as I pull wires off one of the time most of them don't make a difference in the way th boat runs...also a shot of throttle cleaner into the carburetor will immediately back fire(
  6. #6
    Sep 2008
    Maryland - USA
    8,017
    did the wires get renewed when the distributor was?
    maybe its time to do a leakdown test?
  7. #7
    Unfortunately I got it figured out two bent push rods and two broken pushrods that fell down into the head. Milky water in port side head
  8. #8
    Sep 2008
    Maryland - USA
    8,017
    glad you found the source....bummer on the resulting findings...
