Results 1 to 3 of 3
  1. #1
    Default Brass Components in Carbs Getting Eaten Away
    Hello all.
    I've been busy with my J35TEL3EEM 35Hp 3-cyl 2-stroke Johnson recently. The work included removing the aluminium plug at the base of the carb body near the main jet so that the bottom of the emulsion tube was exposed for thorough cleaning.
    For all three carbs, I noticed the plastic float bowl had a green coloured film to them that was difficult to remove. The base of the brass emulsion tube and the main fuel delivery tube were pitted by corrosion. This made me think the green stain in the bottom of the float bowls was actually from the corrosion process.
    Has anyone noticed a similar thing before?
  2. #2
    Join Date
    Jul 2014
    Location
    Buffalo, NY
    Posts
    138
    Default Re: Brass Components in Carbs Getting Eaten Away
    Ethanol
  3. #3
    Join Date
    Apr 2010
    Posts
    4,614
    Salt water in fuel.
Similar Threads
  1. customize parts & components
    By frankhu in forum Minn Kota Trolling Motors Forum
    Last Post: 04-04-2017, 06:17 AM
  2. ignition components and their purpose
    By Portis Left in forum Mercury Mariner Outboard Forum
    Last Post: 09-17-2016, 06:21 PM
  3. 1974 Chrysler Stern drives eaten up, Model?
    By blueboattrip in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 05-24-2013, 08:59 AM
  4. OMC components to mercruiser components
    By jadilla in forum Mercruiser Sterndrive Forum
    Last Post: 04-12-2012, 01:56 PM
  5. OMC Ford 302 EFI Components
    By marshall43 in forum OMC Sterndrive and Inboard Archive
    Last Post: 12-13-2007, 08:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
