Alpha 1 water pump
John4003
So I replaced my Alpha 1 gen II water pump impeller for the first time which was pretty easy but when assembling the unit back together, I forgot to put the little plastic sleeve back on the water pipe. Crap! Is this a necessary part? Doesn't look like it really does anything except maybe help to align the water tube when installing.
The water tube coupling goes on first, then the guide tube.If your 100% confident you got the copper tube in the pump housing ,your good.
