Results 1 to 2 of 2
    Default Aluminum hull repair help
ID:	22465Click image for larger version.
ID:	22466To make a long story short, I have a Lund boat that received damage on the bottom of the hull. A gash that is probably 1/4” wide and a couple inches long.. the gash continues for several more inches but is not through the aluminum completely, maybe 30-50% through... the aluminum is pushed in a little around the damage as well... there is foam behind the damage.. Any suggestions on a course of action? Should this/can this be welded? Patched with rivets and a plate? The pictures are not great. The damage is right under the passenger seat roughly mid hull but on a somewhat flat area. The damage occurs right next to/onto a rivet line where I’m pretty sure a structural support is riveted to the hull. So a backing plate from the inside may not be an option for the full length of the gash...
    Default Re: Aluminum hull repair help
    The first photo almost looks like floatation foam is showing through? I’d find a welder and have it repaired that way. Our neighbors Starcraft got a stress crack that a guy welded up quickly and inexpensively,but does require paint touch up
  1. Sealing an Aluminum Hull
    By ehlien in forum Boat Hull, Deck and Transom Repair
    Last Post: 10-29-2014, 04:16 PM
  2. Need Help with Aluminum Boat Hull cleaning
    By Rick_B in forum Boat Maintenance
    Last Post: 10-26-2014, 10:51 PM
  3. Outboard insulated from aluminum hull boat.. Gonna take it in salt..
    By rocknroj in forum Boat Electrical Systems
    Last Post: 08-01-2014, 12:32 PM
  4. Hull Repair - Self or Pro?
    By johnmedic in forum Boat Hull, Deck and Transom Repair
    Last Post: 09-18-2011, 09:18 PM
  5. Best material for aluminum repair?
    By Goober in forum Boat Hull, Deck and Transom Repair
    Last Post: 12-15-2010, 11:11 AM
