GreenbackChaser
Hi, I have a '73 65hp Johnson. Starts up no matter what, but smoke is terrible, and seems like it floods out at idle. I have to start up, rev the motor, let it warm up and clean out, then go right away. If I stop to idle, more than 2 or 3 minutes, it loads up again, and i have to repeat process. I was a mechanic on forklifts, and suspect either bad float setting or idle mixture. Am I on the right track here ? I've been told that newer ethanol, non leaded gas can hurt the Reed valves. I believe setting carbs should fix the problem. Any suggestions an where to find parts ? Walleye season is coming fast, and I spend every hour on the river. Thanks
