Got this neglected kicker from a friend. It started right away and sounded good but no water flow. Took the lower unit off and the impeller is totally disintegrated. Any easy way to remove the rest of the impeller? I’ve always replaced mine on a regular basis and the impeller just slides off. This one looks to be corroded on. I sprayed some penetrating oil on the shaft and will give it a go after letting it sit a bit. I really don’t want to use heat because I’m hoping just to replace the impeller and not melt other parts.
-Robert
