Results 1 to 5 of 5
    Question Fibreglass hull painting following repair
    Hi Team,
    I'm after some advice on finishing the hull on a Wellcraft Fisherman centre console. It had quite a few scratches and dings which I have repaired with a marine filler and sanded back. Now I want to know if I am able to paint straight over top or do I need to apply all new gelcoat?
    The boat is trailered so not stored in the water and most work that has been done is below the waterline. I'm just trying to get it all back to looking good rather than having patches all over it.
Name:	Wellcraft Fisherman hull repairs.jpg
ID:	22415Click image for larger version.
Name:	Wellcraft Fisherman hull repairs2.jpg
ID:	22416 Some pics for reference.
    Any advice is much appreciated!
    Sep 2008
    Hague, Virginia, USA
    4,792
    Default Re: Fibreglass hull painting following repair
    It's been my experience that Gelcoat does not adhere well to marine filler. You may want to consider one of these new epoxy hull paints. I've heard that they actually hold up better than gelcoat and are much easier to repair and paint over. But I have no first-hand experience with the newer ones.
    CHawk 25 DLX
    Sep 2008
    Maryland - USA
    8,259
    I'd paint it....imron, awlgrip, or alexseal....
    Hi Guys,
    Thanks for the advice. Painting will certainly be a lot easier. Would I need to do a primer first or can I paint straight on to the hull?
    I painted the bottom of my Glastron jet boat with Interlux VC performance Epoxy. Come in white and is vary hard. They sell it on a quart kit If you are painting small areas if not a gallon kit. It a below water product. You can roll it on or brush it. They have thinner if you want to smooth it out.
  1. Hull repair questions
    By RedLeg in forum Boat Hull, Deck and Transom Repair
    Last Post: 11-08-2016, 12:02 PM
  2. Bottom hull repair
    By modelt in forum Boat Hull, Deck and Transom Repair
    Last Post: 02-21-2015, 01:10 AM
  3. Fibreglass boat floor repair
    By yammyfan in forum General Boat Repair Topics
    Last Post: 07-03-2013, 04:57 AM
  4. Hull Repair - Self or Pro?
    By johnmedic in forum Boat Hull, Deck and Transom Repair
    Last Post: 09-18-2011, 08:18 PM
  5. 58 - 60 Cathedral Hull repair.
    By jtw37 in forum Boat Hull, Deck and Transom Repair
    Last Post: 12-05-2010, 12:40 AM
