Thank you for your reply , Racerone . Motor would not idle or run at low revs, coughing spluttering , then would die ,would run at higher revs but would not idle . i have had the motor since 1990 ,experienced the stuck ball bearing in the spring of the the carb .iI almost know the carb better than the wifes ####.Compression at about 115 /120 i am convinced reed valves, electronics ,spark ,coils switch box ,stator not at fault so after reading many,posts i thought i should try replace the top and bottom crankshaft seals which i thought would be easy but now im at a point i cant remove the bottom seal seems you have to remove the wear seal (carrier ,another term i have read) in order to replace the bottom seal. A Great previous post was "should i replace the wear seal "? this i read and appears i have to replace the wear seal to remove the bottom seal,i want to avoid opening the crankcase if possible. Its so nice for someone like you to try and help , i really appreciate your time ,a happy hollday to you and your dearest regards Jeff
