1..... Starting to get a vibration when turning to the port or starboard. Doesn't seem to vibrate going straight.
2..... What are the issues leaving as is until it gets worse?
Thanks. I don’t like the sound of catastrophic. Catastrophic as in dangerous or just expensive?
Both.
Robert, imagine that you are out 10 miles in heavy current when the AFT bearing fails. No more forward propulsion.
I have seen damage range from just the bearing going out, to the PDS taking out the rear flywheel cover snout, to the PDS taking out not only the rear snout, but also taking out the front of the transmission.
V-8 flywheel cover................ $400 used
OHC 4 flywheel cover............ $100 used
PDS................................... $200 used
PDS bearings/seals ............. $70 new
Front transmission collar....... $800/1,000 used and with labor.
Not to mention the labor for pulling a V-8 engine out.
And does the vibration usually warm you and get worse before catastrophe?
I've not been at the helm of a boat when this has occurred, so I can't say one way or another.
I would think that it would be very sudden!
The warning is what you are hearing/feeling now!
