Hello.. sorry if i am double posting but I can’t find the original post that I try to start. I will try to be as detailed as I can.
outboard is a 2001 200hp efi mercury.
engine idles fine and revs perfect on muffs. When load testing the engine in the water it will idle fine but when I give it full throttle it will no go past 2000rpms. After some time with the throttle all the way up, it catches up and revs to full rpm and works as it should . The time it takes varies from time to time.
so far I have replaced fuel lines, water separator, fuel filter, spark plugs(maintenance), primer bulb. Two weeks ago it stop charging and replaced the stator and trigger. The problem still persisted today. I have no idea what else to check. Today Emptied VST and gasoline was dark green but clean. Primed the bulb and gasoline came out perfect yellowish transparent.Any ideas will help .. thanks!
