Click for Honda Manuals, Parts and Model Guides!
Results 1 to 10 of 10
  1. #1
    Default 2002 200hp tilt fluid/
    I have a 2002 ,200hp.After removing the cap, the tilt fluid reservoir tank has a threaded nipple. Is there an attachment I need to add fluid?
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,664
    Default Re: 2002 200hp tilt fluid/
    That sounds strange to me. My 2007 BF 225 does not have a nipple. Are you sure you are looking at the T/T reservoir? See attached.
    Titlt Trim Tank.pdf
    CHawk 25 DLX
  3. #3
    Join Date
    Sep 2008
    Location
    Posts
    4,664
    Alright, trying the attachment again....
    Titlt Trim Tank.pdf
    CHawk 25 DLX
  4. #4
    Join Date
    Sep 2008
    Location
    Posts
    4,664
    Sorry, don't know why that is not working.
    See parts 24 & 25 in this link....
    https://www.boats.net/catalog/honda/...ower-trim-tilt
    CHawk 25 DLX
  5. #5
    Thanks for responding, I will take a photo of it later today. It is snowing here right now. I was able to open the link in the first response.
  6. #6
    Titlt Trim Tank.pdf CHAWK, attached should be a pic of fluid tank.I was able to use a small diameter hose to fill it up. I got it go up and down, added some more and all is good. Thanks
  7. #7
    Join Date
    Sep 2008
    Location
    Posts
    4,664
    Roger that. Once the T/T is exercised after a couple of weeks, top it off again.
    CHawk 25 DLX
  8. #8
    I have another question about my 2002 Honda 200 horsepower. I keep throwing an alarm, 8 blinks. Tells me it's the TDC sensor. From what I can see in my manual it comes as one unit with part of the throttle assembly. Any thoughts and recommendations?
  9. #9
    Join Date
    Sep 2008
    Location
    Posts
    4,664
    Pull the TDC sensor 4P plug and measure resistance across the TD1 sensor terminals - the green and red wires. According to the manual, it should be 2000 +/- 500 ohms. If out of spec, replace it.
    Then test each sensor terminal (green and red wires) and ground. If continuity, replace the sensor. Page 5-101 of the Helm Shop Manual walks you through the replacement. Looks like a real PITA.
    CHawk 25 DLX
  10. #10
    Thank you, I agree with the pita
Similar Threads
  1. how to add power trim tilt fluid 2002 60 hp 2 cycle yamaha
    By jepik in forum Yamaha Outboard Forum
    Last Post: 04-20-2013, 06:39 PM
  2. 2002 Honda BF 130, how to check power trim fluid level?
    By Cohiba in forum Honda Outboard Forum
    Last Post: 11-27-2011, 07:58 PM
  3. Not Getting Enough Fluid in the Lower Unit? 2002 50 hp
    By captb in forum Honda Outboard Forum
    Last Post: 02-14-2011, 04:26 PM
  4. Lower Gear Fluid ChangeHonda 200HP Four Stroke
    By justin_elia in forum Honda Outboard Archive
    Last Post: 12-08-2008, 01:13 AM
  5. Starting fluid 1991 200hp johnson
    By jessielsmall in forum Johnson Evinrude Outboard Archive
    Last Post: 10-09-2007, 03:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
