Click for Crusader parts and manuals!
Results 1 to 4 of 4
  1. #1
    Default 1994 crusader 454 xl tune up kit
    can somebody point me to a PN for oem crusader tune up kit? im carburated 454 xl in a 1994 silverton 34c. ive found a few , but just want to be sure
  2. #2
    Default Re: 1994 crusader 454 xl tune up kit
    also , please let me know what type of coolant these motors use... the orange GM stuff? would like to do a drain and fill
  3. #3
    one more... the remote oil filter, does that return to the bottom of the pan? does installation of an oil change system just tap into this line?
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,076
    I'm sure your local dealer can get you a 'tune-up kit' if desired....personally, it's usually more economical to get the parts thru aftermarket sources...
    They should use the 'older' Ethylene Glycol coolant vs DEX-COOL.
    The majority of the oil change system's I've seen use one of the plugs on the oil pan and leave the remote oil filter 'as-is'.....
Similar Threads
  1. 1994 Crusader 350XL tick at low RPM
    By SDSF in forum Crusader Marine Engine Forum
    Last Post: 07-30-2019, 09:42 PM
  2. Overheating 1994 Crusader 454
    By PTG in forum Crusader Marine Engine Forum
    Last Post: 05-29-2018, 09:28 AM
  3. Mariner 90 HP 1994 Spark problem 1994 90 hp
    By joefl77 in forum Mercury Mariner Outboard Forum
    Last Post: 12-23-2009, 11:04 AM
  4. 57L Tune Up
    By njyankee in forum Mercruiser Sterndrive Archive
    Last Post: 05-03-2007, 04:18 PM
  5. 350 Crusader Engines 1994 with 100 hours
    By Jeff Norton in forum Crusader Marine Archive
    Last Post: 08-09-2002, 12:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
