Be sure. Shift lever wheel is in , shift cable slot.
I think he's talking about the shift mechanism on right side of bell housing where shift cable meshes with shift shaft that goes through the exhaust port.What are you talking about?
usually use grease to keep them positioned during install not removal ....
No issue putting an alpha into gear while not moving done it every time I’ve taken the drive off both my alpha powered boats. I believe there is an issue doing the same with bravo perhaps this is what you readYes only concerned with removal. Seems like I've read where putting them in gear on the trailer is a no no unless someone spins the prop. If by myself I've used a docking line and simultaneously pulled the line and put the shifter in gear. But I've forgotten which way to spin the prop. Maybe I'm overkilling it. Thanks for the responses.
