Invader100
Hello,
Newbie here but by no means new to forums.
First post:
I have a 1980 Mercury 90HP inline six with a broken swivel bracket.
I have the replacement swivel bracket and I have the motor off the boat, the lower unit removed and everything remove from the old swivelbracket.
Only thing left is to remove the swivel pin/arm assembly and swivel bracket but I need to get the shift shaft out of there first.
How does the shift shaft come out?
I see the linkage arm on the top of the shift shaft and a hole through the linkage arm and the top of the shaft with either a small set screw or a roll pin. I was hoping it is a set screw that could be removed, the linkage arm removed and slide the shift shaft out through the bottom. But it appears to be a roll pin in there.
I do not see how I will be able to get a punch down in there to punch out the roll pin. Maybe if I loosen the lower cowl, it might drop far enough out of the way to get a punch onto the roll pin?
It does not look like there is enough clearance, even if I pulled the carbs, to slide the shift shaft out the top with the linkage arm attached?
Any help would be great! Thanks,
Dan
First post:
Dan
