MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 12 of 12
    Default Steering cable! How do I handle this?
    I'm swapping motors. Both are mid-80's Mercury 75HP.
    Yesterday I removed my steering cable at the "old" motor. Loosened the collar at the tube, but even though I fought like hell, I couldn't get the cable out.
    I pulled and yanked and cussed and loosened everything until the entire tube came out, cable inside. First picture below. Problem one.
    Problem two: whoever handled the "new" motor I bought clearly had a similar problem, because they evidently just cut the cable. Second picture below.
    I can't get either cable out of their respective tubes, and I'm not sure how rough I can get with them. I see videos of guys hammering them out, but I don't want to damage them further.
    1. How can I get my good cable out of that tube?
    2. How can I get that cut cable out of my 'new' motor?
    I'm stuck.
ID:	22294 Click image for larger version.
ID:	22295 Click image for larger version.
    Sep 2010
    19,784
    Default Re: Steering cable! How do I handle this?
    Tilt tubes were common for many years.------Same on many brands of motors from 1973 to the present.-----Used ones should be a dime a dozen , at least in many areas they are.-----Use your mini grinder to cut / split the tube and save the cable.----I think that is a simple solution.
    Sep 2003
    New Tripoli, PA, USA!
    16,824
    Have you tried an oxyacetylene torch to heat the tube up?
    Jeff
    Quote Originally Posted by fastjeff View Post
    Jeff
    No, I don't have access to such a thing. Would a Benzomatic torch from a hardware store get hot enough to do the trick?
    Sep 2010
    19,784
    Why not grind it till it splits and replace it with a good used one.-----Dime a dozen in my opinion.
  6. #6
    Sep 2003
    16,824
    Grinding through all that steel is a scary proposition! One slip and...
    Yes, a Benzomatic will work, but it'll require a LOT of heating.
    Jeff
  7. #7
    Sep 2010
    19,784
    It is a simple job to grind that tube off the steering cable !!
  8. #8
    Sep 2003
    16,824
    RIGHT!
    Jeff
  9. #9
    Jun 2013
    Duluth Mn
    2,786
    No need to fight guys both suggestions are very good. If you want to make more heat with a hand-held torch you can use MAPP gas which is methyl acetylene and propadiene which burns at around 3000 degrees versus 2300 for butane and 2000 degrees for propane.
  10. #10
    May 2007
    Ireland,the only country in the world you can go North to go South
    2,136
    I'm with timguy on this. Alternatively,try and drive out tube on "new" motor and on your own tube,place the tube in a vice hanging by the nut,heat,oil and hammer
  11. #11
    Sep 2010
    19,784
    If you use a hammer you will likely ---" mushroom " -----the end of the cable.----Will make it hard to drive it through.----Grinding is painless and simple.
  12. #12
    May 2007
    2,136
    Quote Originally Posted by racerone View Post
    Yes that's true.And grinding is the easiest way or cutting with a fine disc.Steady hand required.
    I probably should have explain my method in full.I had pics somewhere but they seem to have left the building.
    Old socket to fit over end of cable,as close to the cable size as possible,old drill bit or bolt the diameter of the cable end eye and cut to same length as the cable end is wide. Heat tube,spray cold oil/water/keyboard cleaner spray,bleach with hammer,repeat.When it starts to go,it gets easier.
    I agree there are plenty of the tubes on the net for sale,and as cheap as chips,but in my neck of the woods end up very pricey with shipping.So I kinda have to make do.
    Another alternative for djcamera is to knock the tube though on the new motor and just shove in the tube from the old motor.In other words,kick the can down the road for a while.
  1. 11' Foot Boat Steering Cable Flat Rack & Steering Wheel - VG Cond. - $95
    By evh in forum Boat Steering and Engine Controls
    Last Post: 03-10-2013, 09:28 AM
  2. Replies: 3
    Last Post: 07-10-2012, 09:00 AM
  3. Throttle Cable for B502A Tiller Handle?
    By captb in forum Honda Outboard Forum
    Last Post: 09-11-2010, 02:29 PM
  4. Final question 25 hp tiller handle cable
    By cordgrass in forum Mercury Mariner Outboard Archive
    Last Post: 04-08-2009, 10:59 AM
  5. CABLE BUDDY%e2%84%a2 Steering Cable Lubrication System
    By pas_bon in forum Yamaha Outboard Archive
    Last Post: 11-24-2008, 06:42 AM
