I just acquired a 1997 Merc 20 hp. I resealed the lower unit and installed a new water pump. A couple of questions that I’m sure someone can answer for me.
I’m not new to Mercury outboards but I never had one with the knob that is used to prime the carb. I didn’t get a manual with this and my internet searches have come back with no results. Th knob can be both rotated and pulled straight out. For a cold start do you simply pull the knob out and pull the starter rope or do you push it in and out to push fuel into the engine? What does rotating the knob do?
Second, I replaced the water pump impeller and all seals. Once started water came out of the tube from the head but it doesn’t come out in a really strong stream like some of the other motors that I have owned. What is more puzzling is that while it is running, there’s a lot of water that comes out of the area , above the lower unit / cavitation plate, where a section of the shift shaft is visible, by the pivot tube. I’m wondering if the upper seal for the copper tube, at the base of the engine block has gone bad and perhaps much of the water being pumped up to the the engine block is leaking back into the exhaust housing. Any thoughts on this?
Thanks in advance for your help.
