baddog1016
I have been trying to diagnose a no spark issue with my 225 Ficht. I replaced the CPS because of bad ohm readin and I took the starter apart and it appeared to be in good shape. I cleaned and lubricated the starter and put it back on the engine but do no avail. By taking a slow motion video I determined my starter is cranking the engine at about 270 rpm, hence no spark. The voltage at the engine is nearly same as the voltage at the batteries, 12.77 V vs. 12.84V. Cranking voltage at the engine drops to 10.7 or so which from an automotive background doesn't seem terrible to me. I'm ready to replace the starter but am curious at what speed the starter should crank the engine assuming everything is in normal order. I have no reason to think there is a mechanical issue with the engine, when it last ran (September 24) it ran great and there is no significant voltage drop between the batteries and the engine
