doc_stressor
Does anyone know what the ECO light on the HD-4 gauge is about?
I thought that it had something to do with when the variable valve timing shifts over. But depending on sea conditions it seems to turn on even at pretty high rpm. See below:
Edit: It may not be clear from this image, but the ECO light in the upper left corner is green. If you open the image in a new window, you can see that.
