Hi all,
I have a dead tilt trim motor and am looking for a replacement. I tested using black to negative and positive either blue or green and no movement at all.
I have looked at this guide and see they he replaces the whole reservoir assembly. Looks quite difficult. (https://www.youtube.com/watch?v=7Nz-Ev4dLuw) It also seems quite expensive as the reservoir assembly costs around 250AUD.
My reservoir portion seems to be okay as I watched this video and did the drill method to test if the rest of the trim tilt is working and it works fine going up and down. (https://www.youtube.com/watch?v=MKcUCglYSHI)
Is there a replacement for just this top motor assembly? Can this rotor be removed without breaking the fluid seal? Do you think that replacing the stator (outer portion) could solve the issue? What do you think is the best route.
I have attached some photos of what it looks like now.
