I bought the boat about a year ago and noticed after the second use that the Ujoint bellows had slipped off, so I put it back on and tightened the clamp like that.
FYI.... the correct bellows incorporates a bead at the interior of both ends.
The bead fits into a grove at both the flywheel cover snout, and on the FWD collar of the transmission.
Then ran it for about a year, maybe 15-20hrs of use and it ran fine, until one day it started making a loud random popping/cracking sound periodically.
Hard to tell from the keyboard here..... could this be the AFT PDS bearing that is going out?
I then took it out another time and it didn't do it, but then on the third outing, these are short outings, maybe 40 minutes each it seemed like something was trying to bind up, and it would still the engine if you got close to idle rpm.
Stall?
Also the engine would stall if you put it in gear. So I said the heck with this 30 year old engine and ordered a new fuel injected engine and bought a new DP-A outdrive that had been taken apart, inspected, then resealed.
Was the bellows issue corrected when this new DP-A was installed?
Were new PDS bearings installed at this time?
I knew that with the pds bearings the engine had to come out, so I decided to order this new engine and have it installed by a shop.
Very important regarding new PDS bearings:
The flywheel cover grease cavity must be cleaned of all old grease.
After the PDS and new bearings have been installed, the cavity must be Pre-Filled with grease (while spinning the PDS) prior to the seals being installed.
When grease is seen exiting through the ball cage, that is when the new seals are installed.
AFT seal installs in the non-conventional direction.
I'm just curious as to what possibly went wrong. I didn't want to pay to have the old outdrive torn down, I just bought a rebuilt one.
FYI..... your aq271c gm 350 engine requires the 1.95:1 reduction.
No other reduction will work correctly with this engine!
The shop hasn't taken the old outdrive off yet, they're waiting for the new engine. It's finally showing up at the shop tomorrow. As far as how did the oil look? It looked relatively new. It was green, so it still had whatever color dye they used. This was before it had the seizing issue. I guess since their was no evidence of water intrustion in the gear oil it didn't get into the drive even though the bellows slipped off. I'm thinking it's the pds bearings that are seizing, not something in the outdrive.
FYI again regarding a bellows leak, the transmission and water:
When the AQ series drive shaft bellows fails, water enters the area.
This water reaches and rusts the carbon steel seal surface washer on the main drive gear.
As the rust builds, it becomes abrasive.
The abrasion cuts away at the seal lip.
The seal starts to allow water to enter the transmission.
