sandkicker
Outstanding Contributor
The owner's yard did a pump rebuild kit 3 seasons ago. Boat lightly used. There was an issue with a suction leak on raw water inlet to this FWC engine and destroyed impeller on start up this season.
Could not pry impeller off so...
I cut off one vane and sliced down front to back with a broken hack saw blade all the way down to the steel shaft. The bond between the steel shaft and the impeller composite insert is stronger than the bond between the insert and the impeller itself and stronger than the bond between the layers of the insert for that matter.
Any suggestions???
My theory... the composite insert in the impeller wasn't totally cured and the heat of the dry running impeller caused the residual uncured epoxy to set and bond the the shaft.
Any suggestions???
