rinkerroger
Last used my 2002 Rinker Captiva 212 w/ merc 5.0L carb. engine 3 weeks ago and a few times prior to that in last couple months w/ NO problems or symptoms. Off-loaded boat into water and lowered outdrive ( I turned on the ignition so I could monitor the lowering of the outdrive, I remember there was no audible alarm as is usual ). With drive down, pushed neutral button in and throttle forward to start position, and turned the key to start. Boat turned over strong, but no quick easy start as is typical. After repeated attempts and pumping the throttle to full w/ no success, --- fellow boater provided starting fluid. After spraying 2-3 seconds into the spark arrester, 2 sec. pause, turned key and boat fired right up strong and easy, and died a few seconds later as the fluid was consumed. Additional attempts to start w/o starting fluid were fruitless, and with starting fluid started easily but then died.
Unscrewed fuel line at carburetor and no gas or even smell of gas present. We did not notice the customary hum when turning the key on at any time. Last time out boat had been Island hopping a few times before being trailered home. At home used muffs to flush the saltwater out no problem, always shut off water before shutting down engine.
First thought was electric fuel pump, not sure how to isolate and test. 2nd thought is low oil pressure fuel pump sensor switch, and 3rd is that lack of alarm at ignition /key in "on" position. I'm handy but not good w/ electrical tester. What do I do first? Second? HELP?
