Click for Crusader parts and manuals!
Results 1 to 13 of 13
  1. #1
    Join Date
    Nov 2006
    Location
    lakewood, ca, usa
    Posts
    367
    Default Oh oh lots of steam
    Warming up my twin 350s while cleaning the boat. Engines running at 2000rpm for a few minutes. Running smoothly. Turned around and saw a lot of steam coming from starboard exhaust. No water exiting the exhaust. Shut it down. Engine too hot to mess with anything. Will start looking tomorrow.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,182
    Default Re: Oh oh lots of steam
    Let's hope it was steam....no water flowing usually equals burning hoses...
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    11,876
    Engines running at 2000 rpm for a few minutes. ................... No water exiting the exhaust.
    Two minutes without cooling water may have caused some damage.
    Suggestions:
    Pull things apart and look for signs of interior blistering on the exhaust couplers/bellows.
    You will also want to retrieve any impeller vanes/blades that may have come loose and may have become lodged within the system.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
    "Intellectual growth should commence at birth and cease only at death." Albert Einstein
    Please... no PMs! Post your questions on the forum.
  4. #4
    Join Date
    Nov 2006
    Location
    lakewood, ca, usa
    Posts
    367
    Need to find why no water. two weeks ago ran great. Good water flow. Two weeks latter started engine to warm up and no water flow. Both pumps spin with the engine running. Nothing unusual. Need to pull intake to thru hull strainer to see if I sucked up a plastic bag or somehow blocked. Not sure what else would happen instantly at start up.
  5. #5
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,182
    I have had two experiences with what I believe were ice bags (discarded overboard)…..the last one was a while back but at cruise.....the smoke trail was less than 100 yards long when I shut off the engines....took out both hoses coming off the elbows....and we changed the impeller while it was apart.....
  6. #6
    Join Date
    Nov 2006
    Location
    lakewood, ca, usa
    Posts
    367
    Quote Originally Posted by makomark View Post
    I have had two experiences with what I believe were ice bags (discarded overboard)..the last one was a while back but at cruise.....the smoke trail was less than 100 yards long when I shut off the engines....took out both hoses coming off the elbows....and we changed the impeller while it was apart.....
    Hoses of of the elbows?? Exhaust ?
  7. #7
    Join Date
    Nov 2006
    Location
    lakewood, ca, usa
    Posts
    367
    Fixed. Removed intake hose from they hull. Opened shutoff valve. No water. Probing with large screw driver and felt an obstruction. Started working the screw driver and broke the obstruction. Plenty water now flowing.
  8. #8
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,182
    Quote Originally Posted by jclays View Post
    yes, exhaust hoses, from elbow down to the first bend....glad is was short and simple.....hopefully, your exhaust hoses weren't damaged...
  9. #9
    Join Date
    Mar 2009
    Location
    Dresden, Maine, United States
    Posts
    365
    Were you able to see what the blockage was? I would be tempted to dive and make sure its completely clear before running her to far.
  10. #10
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    11,876
    Yes, any exhaust "couplers" or "bellows" that may have seen exhaust gasses without cooling water.
    Without cooling water, these parts no doubt saw high temperatures in that 2 - 3 minutes @ 2k RPM.
    Did you look at the seawater pump impeller on that engine?
    Even a 2 minute run without water most likely damaged it.
    Portland, Oregon
  11. #11
    Join Date
    Nov 2006
    Location
    lakewood, ca, usa
    Posts
    367
    Quote Originally Posted by missnancy View Post
    It was some sort of white calcification very hard but crumbled when I started jabbing it with a large screw driver. I was going to call my diver to pay better attention on the intakes and thru hulls.
  12. #12
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,182
    where was the 'calcification'....in the sea cock or in the thru-hull fitting?
  13. #13
    Join Date
    Nov 2006
    Location
    lakewood, ca, usa
    Posts
    367
    In the thru hull fitting. the sea cock was clear and operational. Seems like the up tube between the clamshell and the sea cock.
Similar Threads
  1. Lots of oil
    By Dave Warner in forum Honda Outboard Forum
    Last Post: 06-24-2012, 11:45 PM
  2. BF225 2005-lots of whitesmoke or steam
    By sqa in forum Honda Outboard Forum
    Last Post: 08-28-2010, 01:16 PM
  3. 454 xl lots of steam on one side
    By fotwins94 in forum Crusader Marine Archive
    Last Post: 05-01-2009, 03:35 PM
  4. Lots of smoke
    By wvff in forum Johnson Evinrude Outboard Archive
    Last Post: 07-03-2007, 07:07 PM
  5. Lots of water
    By joeporito in forum OMC Sterndrive and Inboard Archive
    Last Post: 04-07-2007, 07:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
