edgewaterFish
2007 F225's. The starboard one just started dropping RPM's 200-300 intermittently while on plane. Drops for a few seconds then back to normal then repeats 20-30 seconds later. Also hesitant sometimes throttling up to get on plane and may only get to 5200-5400 RPM full throttle. Most of the rest of the time it runs perfectly well and achieves full throttle. Port motor runs fine so not fuel issue. Just had oil serviced, fuel filter changed and injectors cleaned (problem occurred before and after service so not correlated). VST filter changed out past winter.
Any thoughts?
Failing high pressure fuel pump?
Any thoughts?
