Results 1 to 8 of 8
    Default Bf225 head bolts
    Does anyone know if you can reuse head bolts or do you have to use new after doing valve job on motors?
    Default Re: Bf225 head bolts
    If you are working on someone else's motor it may cost you if they snap better be safe than sorry the manual tells you to check them , a lot of us want to save money and take a chances.
    Jul 2017
    meteghan, digby co, Nova Scotia Canada
    17
    There is no measurement of lenght in the shop manual .it just tells you to apply engine oil to the threaded section and the seating surface of the bolt. Loosely install the bolts in the head, and torque in 3 steps. Torque to 29ft.lb in a cross pattern starting with the center bolts going outwards.Then turn each 50 degrees and additionally 53 degrees. No mention of replacing the bolts. I have reused same bolts many times , no problem.
    Read page 6-68 and 6-70 .2002- 2014 Seloc Manual.
    Sep 2010
    19,509
    Seloc / aftermarket manuals are known to have errors / misleading information.
  6. #6
    Jul 2017
    17
    i have the real Honda manual ,as we are a Honda dealer !!!!!!!
  7. #7
    The point is these are TTY bolts that writer of the Seloc manual specify, s to check these bolts on page 6-68 he sticks to good engineering practices .I give him credit for that .
  8. #8
    Sep 2010
    19,509
    These aftermarket manuals are written to be sold.----Many folks buy them.----Some of these manuals belong in the little house with the 1/4 moon in the door.
  1. New head bolts?
    By guppy in forum Mercruiser Sterndrive Forum
    Last Post: 08-13-2017, 07:45 PM
  2. Anti Seize. for head and head cover bolts
    By Keithm18 in forum Johnson Evinrude Outboard Forum
    Last Post: 07-03-2012, 09:11 PM
  3. Head Bolts
    By jj_lynn in forum Honda Outboard Archive
    Last Post: 10-25-2008, 11:35 AM
  4. Head Bolts and Crankcase Bolts Sealants
    By jagiem in forum Johnson Evinrude Outboard Archive
    Last Post: 01-14-2008, 07:00 PM
  5. Head bolts
    By john nicholson in forum Mercruiser Sterndrive Archive
    Last Post: 05-12-2006, 08:47 AM
