RicardoMarine
Gold Medal Contributor
lots of give and take when buying and selling old stuff.
(are these engines known to crack in the block area a lot was it a common fault i was under the impression it was a freeze problem )
I am not following you on that one!
I was just asking a general question is the block on the 3Litre marine engine a known problem area?
None that would be of any more of a concern that what we would see with any other engine.
Avoid over-heating.
Keep the oil/filter clean.
Keep the engine in full tune.
Use the correct over-all drive reduction.
If Raw Water Cooled, drain it down completely for the winter, and you should be good to go!
