26summersquall
Hey guys new member here with a problem with a new to me 1990 50 hp yamaha. I have fuel dumping out of the main jet on the bottom carb, I have cleaned all 3 carbs, replaced needle valves, seats and floats, adjusted the float height so the floats a level with carb housing when upside down. Installed new gaskets and diaphragm on the fuel enrichment solenoid, but it just keeps dumping fuel out that main jet and when I remove the bowl it doesn't seem to have nearly enough fuel in it to even float the float to close the needle valve. I can't find any leaking fuel anywhere else that would be preventing the bowl from filling, compression is at 125 on all 3, has good spark etc. If I flip the manual enrichment valve open, it stops belching fuel out the main jet, but soon as I close it it starts dumping the fuel through the jet again, I'm stumped!
