What does LCQ stand for?
i figure Low Compression Quench?
Yes... low compression quench.
These typically offer a quench surface that more specifically mirrors the Vortec cylinder head's quench surface, including the swirl point area.
I don’t see piston manufacturer’s listing this style of piston however I get the idea.
Not all manufactures will use the same language.
However, you'll know this piston when you see it!
It’s best to match the piston’s quench area with the flat area of the cylinder heads combustion chamber?
You won't be matching anything re; the combustion chamber itself!
You will want the piston's quench surface to mirror the cylinder head's quench surface that is just north of the combustion chamber!
Using Vortec heads I would want a piston with a kidney shaped profile
See images above!
So if I order a kit, It needs to be externally balanced and all I have to do is use the supplied harmonic balancer?
If you are buying a complete stroker kit, all of the components should have already been balanced.
If you are having a machine shop build this engine for you, I would get them involved in the parts ordering process!
I can use my existing flywheel as is?
I believe that the 5.7 L flywheel is neutral balanced.
Perhaps ask that question of the company who is supplying the crankshaft/kit!
A few more things to note:
.....Depending on your flywheel cover (bell housing in the auto world), you will need to pre-select a flywheel in either the 153 tooth ring gear diameter, or in the 168 tooth ring gear diameter.
.....Each requires a different starter motor.
.....Your Borg Warner drive coupler will mount to either of them.
.....If you have a single bearing PDS with a pilot nose on it, your crankshaft will need to have the correct bushing installed in it!
