mrt214
I have twin bravo 350 and I can't get them to idle when in neutral. I can get them to run at 1600 RPM and above but as soon as I pull the lever back the engine stall out and this is happening with both engines not just one. I have taken 1 carburetor apart and rebuilt and still have the same problem. I have taken fuel lines off of fuel tank and put them separately into 5 gallon of 93 octane gas. Either engine will run as long as I have the RPM up over 14 15 16 hundred RPMs but like I said as soon as I pulled back and go into neutral the engine stall. The engines will start with levers pulled back but will not continue to run. Any suggestions on what I can check next would be great I'm just wondering if there's something in the linkage that's preventing it from running at idle at this point I cannot even shift gears to move the boat.
