Buying a new Sea Ray Boat. Standard engine is a Mercruiser 6.2L @ 300 HP. There is a very expensive option to go to 350 HP using the same engine which I would like to do due to boat weight and passenger capacity but the price is pretty extreme. There are no differences in the specs and I am told by Mercruiser the only difference is the ECM. They get 50 more HP with a different ECM? I find that hard to believe having worked on a lot of engines in my time, but that's what they tell me and that's what I have read is possible. Someone in another forum said the props are changed also. Don't know if that is true or if that would help.
So I am asking if anyone has knowledge of this topic. Is it only an ECM that does the job? If it's only the ECM, then can an ECM for the 350 HP be slapped on to a 300 HP engine without a problem and get 50 more HP? Is something else required? Mercruiser was not much additional help.
