Thirsty Turtle
Did a water pump service on my lower unit. Put the lower back on, and it wouldn't go into reverse unless you rotate the prop slightly. Took it off, indexed the male section on the lower unit to neutral. Re-installed the lower again. Now it won't go into forward unless you rotate the prop slightly. I've taken the lower unit off and reinstalled over 50 times. I've put it on in forward, neutral, and reverse. I get the same result. It's like I'm a "tooth" off in the shift shaft coupling. Only forward or only reverse will work. It's one or the other, unless you manually turn the prop shaft. When I do this, it kind of "snaps" back in. It isn't the control cables or binnacle. When I reinstall the lower, the shift shaft slides in fine- EVERY time. But it still won't work. I am at a loss. Any help would be appreciated!!!!
