NewBoatDaddy
Hey yall.. I'm a first time boat owner, lloonnngggg time mechanic. im completely stumped here and need some help since, it is a boat, and not all of the mechanics from auto cross over
To start
1996 regal valanti 176
3.0 mercruiser i/o
Dual batteries thru a perko switch. Pretty standard other than that
So, in my first few times taking her out, because of my ignorance to boats, I ran her on both batteries.......idiot move apparently. Now, I have no charging. I had to replace one battery and thought i needed to replace the alt. Did that twice, no change. Will not charge. If you take the battery cable off the outlet lug on the alt, you can watch the voltage slowly drop.........I've run thru and cleaned all of the grounds and gotten the total resistance down to under 2 ohms. The purple wire will fluctuate between 2 and 10.5 volts while running. The red wire will not show full battery voltage.
PLEASE HELP!!!!!!
THANKS
To start
3.0 mercruiser i/o
PLEASE HELP!!!!!!
THANKS
