I've been working on this 1968 Johnson 3hp for most of this summer. Initially it wouldn't run so I rebuilt carburetor and fuel pump to get it running. I took it out today since I hadn't run it in a couple weeks so I took it out on the lake for awhile and I noticed some problems I was hoping to get help with. First of all after warming the motor up for 10 minutes or so I opened up the throttle slowly. The motor vibrates quite a bit and at WOT there is a kind of machine gun chirping. It's hard for me to describe, but if you were to pair a whistling noise along with the noise made if you hum into a fan, that would be in the ballpark. When I heard that I backed off to 3/4 throttle and it went away. After that I noticed that the cowling was hot to the touch so I brought the throttle down to headway speed and went back to the dock.
After taking the motor into the shop I noticed that there was some peeling paint on the outside of the head, especially around the bottom spark plug.
I did a compression test a few hours later, the top reading 60psi and the bottom reading 58psi.
I decided to take the head off to see if there were any blockages in the water passages, but while doing so I noticed some threaded holes on the top of the powerhead that looked like they were missing some bolts. I looked at the parts diagram and I can't find anything that corresponds to it. I'll try to post a picture of what I'm talking about.
While removing the head, there was a trickle of water that leaked out. I tried for a second to remove the head gasket, but it immediately started tearing, so I stopped there until I got a replacement head gasket and some help from the esteemed members of this forum.
https://ibb.co/7JnZm53
https://ibb.co/5Y1n3tc
