Shade tree
How to replace grommet between water tube and powerhead
Yeah I already replace the impeller put a whole new pump in it actually once you got it fired off not much water was coming out of Tell-Tale hole but there was a bunch of water coming out of the weep hole in front of the gear case so I'm assuming but that grommet between the power head in the exhaust tube is bad appreciate your info thank you
Possible also that you did not locate the water tube in the bottom grommet properly when you refitted the lower unit
